Sony STR-DB1070
Discussion in 'AV Receivers & Amplifiers' started by hunkiemunkey, Jul 28, 2002.
Tags:
  1. hunkiemunkey
    hunkiemunkey
    Jul 17, 2002
    88
    What do you all think of the Sony STR-DB1070?
    I have read mixed reviews
    Also what is the cheapest you can buy them for?
    Many thanks
    John
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    Cheapest i've seen is £299 from Richer Sounds, bare in mind that isn't a UK spec model (most likely european spec) but I dont think it makes a lot of difference. There's a STR-DB1080 coming out very soon that will support DPLII and have more features, but I recon it'll be £399-£499 when it first comes out (at the Sony Center). I've not listened to either so I cant pass comment.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    The forum search facility is quite useful as there must be hundreds of posts on this model.
  4. Craig_Nike
    Craig_Nike
    Just becareful apparently it is being updated by the 1080 2nd half of this year ?
  5. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    As Ian J says - there are plenty of past threads on this amp - I spent about a week trawling through most of them when I was looking to buy...!!! ;)
    Make sure you listen to the 1070 before you buy one - it seems to be a bit of an "acquired" taste - read the threads and you'll see what I mean. Chuffed to bits with mine :)
    Kelvin :D
