sony str db1070
Discussion in 'AV Receivers & Amplifiers' started by jonna, Mar 26, 2002.
Tags:
  1. jonna
    jonna
    Mar 25, 2002
    3,144
    Cheshire
    +2,266
    Just bought my sony amp last week to replace my older 'yamaha dsp a5', really pleased with it but - my yam had a dsp mode that allowed you to listen to music from all speakers and it sounded brill' , the sony has the same-ish kind of feature but it sounds terrible even though i've tried to adjust the settings . Any help on how to achieve '5 channel stereo' affect that sounds not to echoeeeeee .
  2. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Tbh i would listen through the two fronts only.There are some dsp modes but they in no way enhance the experience.Sorry.
  3. paiger
    paiger
    Digital Sound Processing is mainly used to enhance soundtracks for video or TV, not 2 channel music. All you are doing is taking the 2 channels and trying to extract something that isn't there, causing a naff sound. I have never heard a DSP effect that sounded good on music but if your Yammy did then it was a one off.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    All of the DSp's on the 1070 are fully configurable so you you should be able to adjust any of them to receive the effect that you want.
