sony str db1070
Discussion in 'AV Receivers & Amplifiers' started by laustin, Feb 9, 2002.
Tags:
  1. laustin
    laustin
    think about geting the sony strdb1070 do you have to use the 6.1 because i am going to use it as a 5.1 is that okey thank
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    In the set up menu just tell it that you don't have a rear centre speaker.
  3. laustin
    laustin
    thank for that and what is the best outputs to use on my dvd player 5.1 outputs or the digital cable
  4. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Digital Co-axial cable as the deocder in the amp is likely to be better than the one on your DVD player
  5. laustin
    laustin
    thanks for your help
  6. Craig_Nike
    Craig_Nike
    hey laustin - dont forget you can have 'phantom' 6.1 without the centre rear speaker - like IanJ says - tell the set up that you have no centre rear - but then when you are playing a DVD - activate 6.1 decoding (cant do that when your on AFD, try Normal Surround or Cinema Studio B sound format) and the 1070 will produce a 'phantom' speaker where your 6.1 would be.
    Obviously its not as good as having one, but better than nothing?
    Hope this helps.
