sony str-db 790 info help!
Discussion in 'AV Receivers & Amplifiers' started by kiddi, Nov 8, 2003.
Tags:
  1. kiddi
    kiddi
    does anybody know if the sony str-db790 has an on screen (tv) display for menu and such??
    I just got it and it sounds great out of the box, have to run it in a little to really find out tho. The manual is the worst I've seen...
  2. Grimley
    Grimley
    Sep 19, 2003
    870
    Deepest, Darkest Essex, so BEWARE!
    +98
    If it has a monitor (composite & S-video on the back) of the unit it should have as my 3 year old Sony 940 has got it. Have a look in the manual under 'OSD'
    HTH
  3. kiddi
    kiddi
    thanks. the manual could as well be in chinese though!
  4. Grimley
    Grimley
    Sep 19, 2003
    870
    +98
    Yeah, I know you mean, I'm trying to set a home network currently & the tech stuff on the web on how to do it is mindboggling!
  5. krusty
    krusty
    zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
  6. redskorpion
    redskorpion
  7. bob1
    bob1
    Nov 7, 2002
    4,324
    Sheffield
    +129
    :confused:
    redskorpion could you direct me to the manual for the sony 1080 please ,i've looked but can't find it.
  8. redskorpion
    redskorpion
  9. bob1
    bob1
    Nov 7, 2002
    4,324
    Sheffield
    +129
