Sony STR DA 1200ES Connection problems
Discussion in 'AV Receivers & Amplifiers' started by noobie86, Sep 22, 2007.
Tags:
  1. noobie86
    noobie86
    Sep 22, 2007
    12
    :lease:
    Hi Peeps
    New to all this home theatre malarky so bear with me please. Can anybody help me? I have just purchased the Sony receiver 1200 and I am clueless as to how I can connect my Wii via component to amp/receiver and through HDMI to TV. I have made the connections but all I get is sound via audio but no picture? Am I missing some receiver setup procedure? The Wii works fine direct to tv?
    Thanks in advance for any advice
  2. PWinwood
    PWinwood
    Aug 14, 2007
    81
    Abingdon
    +14
    Unfortunately the STRDA1200ES does not upconvert Component to HDMI, it just switches. Therefore to use component out of your Wii you need to plug component into your TV. It does upconvert composite and S-Video to Component (576i) however.
