M
max101
ok guys i'm on the last leg. last smidgen of help required on the topic of connectivity.
my dvd ( sony 405 ) is connected directly to RGB on tv ( scart to scart )
digital sound from dvd into amp via short optical.
a little confused though with the NTL set top box connection though. I want to get the DPL2 effect ...... ( until ntl get their finger out and start broadcasting 5.1 )
I though either
a) existing scart out of ntl STB to svid scart on TV.
Then run sound back to amp via phono leads from back of TV
or
b) run from scart on ntl stb directly to amp via a scart to svid cable. then connect from svid socket up to the tv's scart svid
hopefully both methods would give the DPL2 ?
but which one would provide the best sound and picture ?
I though either
or
