Sony Ss600
Discussion in 'Home Cinema Buying & Building' started by andy_mfc, Mar 18, 2006.
  1. andy_mfc
    andy_mfc
    Dec 11, 2005
    240
    Middlesbrough
    hi ive just purchased one of these and have got it all set up but im well confussed with all the functions it has. can any1 tell me step by step the best way to get the best sound from all speakers for movies, 360 etc plz
  2. Caveman643
    Caveman643
    Jun 16, 2005
    516
    Harrogate, UK
    +51
    Hi, I got one of these the other day. The easiest way I have seen so far is to use the AFD button on the remote. Keep pressing it until the screen on the AMP says AFD Auto. This will then set the outputs for the speakers according to what the input is. So if the source id DD5.1 from a DVD it will output DD5.1
    It works well and I'm impressed with this piece of kit. At last I'm getting proper sound when listening to DVDs and movies through my Sky+ box. :thumbsup:
  3. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    Only use 'AFD' when feeding it a digital signal from a dvd film, otherwise you'll only get sound from the front speakers. For all other sources, use Dolby ProLogic II - this creates a convincing 5.1 surround sound from ordinary television programmes/films.
