neosalad
i am new to these forums, but here is my query.
I have a Yamaha RX-357 AMP (http://ws1.froogle.richersounds.com/showproduct.php?cda=showproduct&pid=YAMA-RXV357)
which i am very happy with, and have been using it with the following set of sony speakers : Speaker Package (SA-SC8/RU3) (http://welectronics.com/stereo/SONY SA SC8.html)
that i managed to get, but without the SUB or the AMP/DVD (they were part of a package, and they were missing from when i got it...)
i have been using the system with the LFE going via the front speaker channels, but i have been able to get a Sony sub that pretty much matches the kit i have already, it is the following model, Sony SS-WS5... (which is from a set, but missing the other speakers)
it's description is as follows....
Passive Subwoofer: The subwoofer features an upward-firing 6-3/8" cone woofer in a bass-reflex enclosure. The subwoofer is powered by 100 watts from the changer/receiver.
Speaker Wiring: Each length of supplied speaker wire has tinned wire on one end, and a color-coded proprietary plug on the other for easy hookup. purple (Subwoofer).
I thought it was going to be fairly straight forward to conenct up this sub, but now i am not so sure. the sub has a standard wire type connection as most speakers do, but the connection on my amp for the sub out is a round one which i think most subs use... is it possible to get a connection that links them, as i seem to see only leads the same at both end for conencting subs (like a phono plug type)
if it is any help, from searching on the net i know the sub is a "passive" sub, but the manual from yanaha mentions yamaha active sub, but i assume i can also use passive also, as active is just powered ... yes?
and ......
thanks in advance for any help!
neosalad
and ......
neosalad
