sony srs-nwn10 docking station
Discussion in 'Headphones, Earphones & Portable Music' started by ivor61, Mar 16, 2006.
  1. ivor61
    ivor61
    May 4, 2005
    41
    olney
    has anyone got this docking station for nwa 1000/3000 players
    is it any good and what is the base sound like
  2. tonyb_uk
    tonyb_uk
    I've got this docking station, it looks very good, matches my silver A3000 a treat and the under unit light is a nice touch.
    The sound quality is very impressive given the size of the unit, at 4W output it's not going to fill a large room with music but for my home office (aka back bedroom) it's enough and doesn't distort at high volumes. The bass is not bad for such a small unit, I'd described it as controlled. There are no EQ controls on the docking station and it switches the A1000/3000 to line-out mode so the DAP's EQ setting are off when docked so I'd try and listen to the unit before buying if bass is important to you.
    When running off the mains it will charge the DAP both in play mode and when connected to the PC. Haven't tried running it on batteries so I can't comment on how long they'd last.
  3. ivor61
    ivor61
    May 4, 2005
    41
    olney
    thank you for your reply:smashin: it seems quite a good add on
