Sony Speaker Cable for DAVS300
Discussion in 'Cables & Switches' started by moosie, Jun 23, 2005.
  1. moosie
    moosie
    Apr 25, 2005
    63
    Have a Sony DAVS300 home cinema player which I need to have miles away from the telly.
    The problem is that the speaker lead (centre) is too short to reach the telly. I can't seem to find a cable with the Sony connection on it. Any ideas. :lease:
  2. fuzzb
    fuzzb
    Did you have any luck with this? I'm looking for some Sony cable for my Sony HTK250 Home Cinema kit.
  3. welshguy
    welshguy
    Jul 16, 2005
    20
    guys I had the same rob yesterday believe it or not. you can remove the plugs at the ends (underneath thers a pin thingy you push in). Snip and extend your speaker wire then re-connect.
