Sony sound problem.. can anyone help??
Discussion in 'Home Cinema Buying & Building' started by John Birch, Sep 22, 2004.
  1. John Birch
    John Birch
    I have a Sony DAVS 400 Home Theatre with a sound field setting locked onto "Headphone Theatre". It will play sound through headphones but not through the external speakers.
    I cannot bring up the other sound field settings.
    I have obviously removed the headphones!
    Can anyone help please??
    Thanks.
    John Birch
  2. casteels
    casteels
    Hi John,
    Since yesterday I have exactly the same problem. I have allready removed the phone jack inside the davs 400 (I thought the connector got stuck) but it did not help.
    Did you find out something ?
    Thanks,
    Paul Casteels
  3. teco
    teco
    yesterday this happened to me too!
    when i turn the player completely off, it works normal for a few minutes, then the headphone function comes back... i have never even used headphones!
    have you solved the problem?
  4. TREEHORN
    TREEHORN
    This too happened to me
    Any ideas????
  5. himdman
    himdman
    This is caused by some poor solderings on the Amplifier board.
    Resolder the connector wich leads to the HP board.
    Also check the soldering of the coils and the power capacitor.
