Sony software upgrade
Discussion in 'Satellite TV, Sky TV & FreeSat' started by alim, Feb 18, 2003.
  1. alim
    alim
    I have a strange problem where my power led indicator flahses between green and red 12 times; then pauses and does it again. The flashing only stops when you switch the set off and on at the mains. The tv does continue to work perfectly even while the led is flashing. It only occurs about once every 2 weeks.
    Anyway Sony say they are aware of the problem and will be transmitting a new software upgrade to remove this problem. I think the transmissions are due to start on the 21st of Feb. for 4 days.
    By the way I have a 36NX200.
  2. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
    It's happend to mine too, 32DX40U. I think it started happening after the last software upgrade in January as it was fine 'till then.
  3. bar
    bar
    Nov 28, 2002
    48
    Manchester
    I have the same problem very ocassionally on my DX40.
    If i press standby and standby again to turn the tv back on it seems to be fine.
    Im sure it happened on my before the software upgrade.
  4. Timh
    Timh
    Sep 14, 2000
    4,823
    Altair-4
    +140
    what software version do you have? Sony sent a friend an upgrade card to upgrade to v 2.12, I borrowed it and upgraded my KP-41ds1u from v 2.01 to v 2.12.
    My set seems OK.
  5. big10uk
    big10uk
    Any got to the bottom of this ????
  6. Timh
    Timh
    Sep 14, 2000
    4,823
    Altair-4
    +140
    Just checked and my software seems to have upgraded to v 2.13
  7. big10uk
    big10uk
    My Digital Setup versions are:
    Version: r3.0
    Loader: v1.01
    36NX200U + DAV S8
