Sony SLV-D900 VHS & DVD combi Hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Justin@UH, May 30, 2005.
  1. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    Multiregion hack for this samsung based model is as follows:
    With the player is switched on, with no disc and in DVD mode:
    On the remote, press:
    Subtitle
    3
    7
    7
    You will now get a message on your TV screen the current region.
    To change current region, press "1" on your remote for region 1, "2" for region 2, or "9" for auto regions.
    Cheers ;)
  2. papabear
    papabear
    May 26, 2005
    93
    11
    London
    unfortunately this hack doesn't seem to work on the slvd980 can you suggest another option please
    :suicide:
  3. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    +93
    This hack is only for the SLV-D900. None of the other sony combis can be modified, only the 900.
  4. papabear
    papabear
    May 26, 2005
    93
    11
    London
    thanks mate
  5. lindahartman
    lindahartman
    that's the one I have. If there is no hack for this, can you change the chip?
    or make any other modifications?
  6. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    +93
    No other sony combi can be modified by any means.
  7. Chando
    Chando
    Dec 4, 2008
    hi, i have the d900 and tried the hack but im not seeing the message box appear
    am i missing something?
