Sony service menu question (tried everywhere)
Joe Pineapples
Had a good trawl through the search engine on this site, and google. So far, with my Sony KV2532U, i have managed to get the usual 'TT' displayed, and typing (T)13, brings up the software version info. But i dont seem to be able to get any actual service menu (and its info) on the screen. I tried pressing the 'menu' key twice, but all that does is bring up the normal tv menu and hide it again.
any ideas?
cheers
Dean
P
Paul Atreides
First of all don't enter any numbers into the TT screen, you can seriously cripple your TV unless you now what they mean.
How are you entering service mode? Sounds like your using the button hold method, I use the remote control code and it works 9/10 times for me.
If you don't know the code it's: Info > 5 > + Volume > TV
P
Paul Atreides
Keep trying, it should work.
Timing is important, make sure you press the buttons within a second of each other.
Podcast: Hisense A7G, Zidoo Z1000 & Kudos Cardea C10 Reviews + Movie News and Reviews
