sony sc5 black and white
Discussion in 'Home Cinema Buying & Building' started by merc190e, Oct 15, 2004.
  1. merc190e
    merc190e
    Apr 9, 2004
    Just got a sony davsc5 system which has been made multiregion, i have tested both region 1,2 discs and found they both work. But the region 1 discs seem to coming in black and white
    I have connected it via the scart, not sure if this makes a difference ??
    Also i have changed the setting on the player from 'Line' to 'RGB' which makes it colour, but puts a pink tinge on the screen :?:
    anyone got any ideas ??
    Not sure if i need another cable or connection maybe ??
