Sony S9000ES
Discussion in 'Blu-ray & DVD Players & Recorders' started by robertseymour, Feb 28, 2013.
  1. robertseymour
    robertseymour
    Jul 24, 2006
    636
    Swindon/Oxford
    +80
    Anyone still use one?
    [​IMG]
    Sony DVP-S9000ES by RSdesignUK, on Flickr
    Mine is great for CD replay, hardly skips but on DVD disks it skips a lot, even if the disks are new or clean.
    Tried disk cleaners and the like.
    Any ideas?
    Its a shame as I think it still looks OK on video, even at 480p :laugh:
    Obviously not as high resolution as the PS3 or Panny Bluray I had, but it 'looks' good, colours and graduations etc.
    Also, any idea what the 'jog' button does on the remote? All it does is the button lights up red when pressed :D
  2. DELUCAS
    DELUCAS
    Feb 11, 2004
    4,809
    KENT
    +942
    First port of call would be faulty laser !
    Quite a common falure point on early sony dvd players
    The lasers have two as such one to read cd and other to read dvd
    Hence the issue of ....
    I have a minty mint sony S7700 gold cant bear to part with it !
  3. robertseymour
    robertseymour
    Jul 24, 2006
    636
    Swindon/Oxford
    +80
    Cheers, may not be economical to repair. Will stick to using CD's then, no bad thing as its a cracking player!
  4. fuzzybk
    fuzzybk
    May 12, 2009
    239
    Ontario, Canada
    +36
    My S9000ES developed a problem with the disc tray mechanism. Over time the tray would fail to open completely. You could hear the motor trying to open the tray but it would just open an inch then close. I was told by a Sony tech years ago that it is impossible to find parts to fix the tray.
    Do any other owners have a problem with the tray mechanism?
  5. robertseymour
    robertseymour
    Jul 24, 2006
    636
    Swindon/Oxford
    +80
    Mine is a little slow when first turned on, but speeds up after one or two tray loads.
  6. simonblue
    simonblue
    Jan 29, 2006
    19,716
    163
    +8,882
    They dont alway need new parts,my Oppo 83 started doing the same took it in to them the tray just needer realignmemt and a bit of greaseing :)
