Sony S380 now under £100
chris
Sevenoaks are doing it for £99 multi region at the moment, but if you do a price beat with richer sounds you will get it for £94.
But richer dont sell multi region ones.
bluelouboyle
Holy ****, S370 for 69.99? RESERVED. Finally i can go blu.
And last week THIN RED LINE for 6.99? A good week methinks.
bluedroog
Where's that?
And sorry remind me again, as I keep geting BR models in a muddle! The 380 is the newer version with more bells and Whistles but the 370 for pure performance is the one to go for?:lease:
Edit - Doh, read the post above now...
bluelouboyle
Ok that was a screw up. I reserved the S370 for 69.99. I collected it. I took the box out and...
It's the S380!
Anyone experts on both? Should i swap it for the S370 or not bother? If I keep the S380 will it affect my warranty etc. It was their fault.
(In the shop I assumed it was the s370)
RMCF
Your local Argos might not have a 370.
The 370 and 380 share the same Argos Catalogue number, so I guess that they simply replaced the 370 with the newer model when the 370 went out of date.
Scott_Mac
It does seem that the S370 is the one to get for performance... S380 has more features.
However, from my limited testing, the 'average punter' wouldn't spot the difference!
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
