sony s350 help?
Discussion in 'Blu-ray & DVD Players & Recorders' started by gunner84, Feb 6, 2009.
  1. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    hi
    im pretty certain this is the player i want to get but i just have a couple of questions,
    is this player profile 2.0 out of the box , or is there an update available for profile 2.0?
    also
    i have a ps3 , would i see an advantage in picture and all round performance if i got the s350?
    thanks
  2. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Hi gunner84. :)
    It may already be on new firmware so will be profile 2.0 otherwise it's a quick update to get it. :thumbsup:
    All the best.
  3. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    i just checked a cnet review and he mentioned something about usb storage on the back of the player would i need to do that if i was to update, as he says you need a very slim usb device as standard ones dont fit??
    cheers
  4. unfitgit
    unfitgit
    Nov 12, 2008
    108
    16
    You can connect straight to your internet source or download firmware from web and burn to cd and load via the disc, i did the disc version and worked fine.
    Or you can store it to usb stick and load via that as mentioned
  5. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    oh i see , so i can download straight to it using ethernet ?
    cheers
  6. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Yes. :thumbsup:
  7. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    i dont get it in the cnet review the bloke states to use the profile 2.0 features you will need to add usb storage to the device?
  8. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    You need the extra memory for BD Live content yes :) plus of course player connected to the net.
    If the player is "not" profile 2.0 then you'll need to update the players firmware,connect via ethernet to download or download from Sonys site and burn to CD....spin disc in player to update.
  9. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    ok , but can i still update to 2.0 without the extra usb memory storage?
    thanks for the help
  10. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Yeah. :smashin:
  11. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    thats good then because i dont really use the bd live features , just one last thing , do you think i would see an all round advantage from my ps3 bluray to a standalone ?
    im still getting a standalone for downstairs living room.
    cheers:)
  12. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Different opinions everywhere you look on this :D same say,none,some say subtle sone even say HUGE :eek: whatever,no doubt you'll love the player anyway. :thumbsup:
    All the best.
  13. WrexTheDragon
    WrexTheDragon
    Dec 28, 2008
    81
    Salop
    +16
    Standard USB memory sticks works fine on my machine, it just sticks out a bit on the back. I have tried 3 different ones.
    Make sure you format the memory as FAT, mine was formatted as NTFS and the S350 could not see it.
  14. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    the s350 is cheaper than the panny bd35 , thats why im thinking about getting the s350 , but for the extra £20 or so quid do you think the bd35 would be better ?
    thanks
  15. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Maybe a touch better DVD? :) there are similiar though.
    All the best.
  16. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    s350 it is then , i personally like the design better on the sony seems smaller?
  17. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    ah one final point has the sony s350 got a optical connection for my 5.1 sound system?
    thanks
  18. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Optical out yes. :smashin:
  19. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    i wonder how good the picture will be on my panny 37"pv500 plasma with the s350 , i was thinking about getting a new tv set but i cant get anything bigger than a 37" anyway because of room , but i think the pv500 has a quality picture to rival a lot of new sets still????
  20. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    It isnt they are near identical, ( in size and even PQ ) I have both:)
  21. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    hi is it possible to make the s350 bluray multiregion ?
    cheers
  22. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Not by hack or firmware :( sorry.
  23. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    i suppose it does'nt matter as i rent most of my films , so i have to wait anyway , i only ever buy a film if it is really good and sometimes there multiregion as standard
  24. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
  25. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Last couple of large items i had from Play came within two days so not bad. :smashin:
  26. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    im really excited about getting this player but its such a close call between this and the bd35:rolleyes:
  27. crimson chin
    crimson chin
    Jun 30, 2004
    115
    a big :smashin: from me for the sony......
  28. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    guys ive taken the plunge and ordered
    thanks for all your help:thumbsup:
  29. coops233
    coops233
    Oct 20, 2005
    899
    Milton Keynes
    +50
    Biggest improvement for me on this player compared to PS3 is the sound via bitstream. :thumbsup:
    Shame the PS3 cannot send audio via bitstream.
  30. gunner84
    gunner84
    Aug 16, 2005
    4,303
    +1,043
    hi
    im after a hdmi cable for the s350 anyone know the best place to get a good quality cable for reasonable price?
    thankyou:)
