I was looking at the 2 Sony models KDL40S2010/KDL40V2000 as I wanted to connect my media centre which currently has only VGA out. I noticed that most posts same the v series is better than the s series, but from what I can see, the v series doesn't come with a 15-pin vga connection but the s series does?
so can someone(s) confirm
1. v series is better than the s series
2. v series does NOT come with a VGA
3. Would the Samsung R73/R74 series be better than the s series, which comes with a vga
I suppose I could buy a vga to component converter or a new graphics card with DVI out to connect to the v series, but that is more expensive and the v series is the dearer out of all 3.
Any recommendations/comments
Thank you
Thank you
