sony remote for 1271Q ?? Roland , anyone???
Discussion in 'Projectors, Screens & Video Processors' started by gizlaroc, Jun 28, 2002.
Thread Status:
Not open for further replies.
  1. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Does anyone know whether the 1270 remote works with the 1271q , i know that everyone uses the 1271 remote but there is also a 1270 which has about 2 more buttons and apart from that is exactly the same.
    The guy who has it seems to think it is fine but I just wanted to check.
    a quick yes or no would be greatly appreciated.
    cheers
    Giz
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Basically they are the same but as you say just a couple of the buttons will be different. You'll just have to go back to the PJ to make those commands.
    If its cheap go for it.
    roly
  3. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    thanks roland
    just what I wanted to hear :)
Thread Status:
