Sony RDRHXD970 recording
Discussion in 'Blu-ray & DVD Players & Recorders' started by boristhespie, Jan 21, 2008.
  1. boristhespie
    boristhespie
    Aug 22, 2005
    72
    +7
    I never get this thing to fast dub from HD to DVD. I also have diagonal lines on my 28 crt tv when viewing freeview when hard disk is in operation.
    However can someone tell me if it is possible when dubbing from HD to DVD to watch freeview, as to put i bluntly having to be stuck with real-time dubbing and without tv to watch is bugging me.
  2. ramjet
    ramjet
    May 21, 2006
    3,761
    +622
    it can only fast dub on a recording with no transitions , otherwise its in real time and then you cannot use the machine for anything else
    try a halfhour bbc1 program and see if that fast dubs ok
    check your scart lead is ok as you should not be getting lines on the tv
    its always worth buying a freeview tv , or having a freeview or sky or virgin box plugged into the tv for alternative viewing
    otherwise , do your standard dubbing overnight
  3. JH4
    JH4
    May 6, 2003
    2,463
    83
    +299
    Fast dubbing: Pages 101,156. (Also not possible if the file size is too big to fit on a DVD blank.)
