Sony RDRHXD560 - 2 questions re RGB passthrough & Timer record
Discussion in 'Blu-ray & DVD Players & Recorders' started by Steve Tustin, Apr 22, 2007.
  1. Steve Tustin
    Steve Tustin
    Jul 10, 2004
    100
    I just got an LG RH188S from Richer Sounds as a warranty replacement and whilst it seems a simple enough beast it appears that it does not a) have RGB passthrough and b) you have to actually switch the unit off to make a timer recording work!
    Does anybody know if the above <ahem!> features are also true of the Sony RDRHXD560?
    Many thanks
    Additional questions if I may:
    I have NTL - so can I use both NTL and FreeView with the Sony? Or do I have to pick 1 or the other? For instance, if I want to record a movie that comes in via NTL, can I still do so? Finally, are there any downsides to this setup?
    All help much appreciated so I can "swap out" inside the 7 day period allowed
