Sony RDRHX900 DVD playback problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by dandy, Dec 3, 2004.
  1. dandy
    dandy
    Before I send the recorder back to digital-point, I thought I would ask you helpful folks whether you've seen this problem before.
    It's a multi-region player. When playing commercial R2 PAL disks such as Crouching Tiger, Hidden Dragon, the picture has no red and green data and the image is jerky. The strange thing is the fault only appears on the YPbPr output and not on the RGB and composite outputs.
    It's not a cabling problem because Freeview pictures are fine when viewed on component output.
    Sony technical support was unhelpful to put it mildly.
    Thanks for any comments.
