Sony Rdrgx120 - Hack?????
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by THERAAAVEN, Mar 27, 2006.
  1. THERAAAVEN
    THERAAAVEN
    Jan 31, 2006
    587
    ruislip
    +10
    anyone got or know of a hack for the SONY RDRGX120 - dvd recorder. thanks
  2. papabear
    papabear
    May 26, 2005
    93
    11
    London
    the normal sony hack will not work on this unit because it's a LG unit. try using the banner at the bottom of this thread.
  3. THERAAAVEN
    THERAAAVEN
    Jan 31, 2006
    587
    ruislip
    +10
    I thought the rdrgx210 was an lg based machine - this seems to be a philips as it only records onto +r/+rw discs
  4. THERAAAVEN
    THERAAAVEN
    Jan 31, 2006
    587
    ruislip
    +10
    hold on just done it!!!!! to hack this unit it is the hack with the all for one remote BUT you have to enter the system menu of the recorder! was playing about and it worked!!!!! thanks
  5. Justin@UH
    [email protected]
    Feb 21, 2002
    2,194
    63
    Location location location
    +94
    Not on a 210 it won`t....
  6. Justin@UH
    [email protected]
    Feb 21, 2002
    2,194
    63
    +94
    ? It is (LG OEM), and no it doesn`t! A 210 records to plus (+) and minus (-) discs!
  7. THERAAAVEN
    THERAAAVEN
    Jan 31, 2006
    587
    ruislip
    +10
    this unit is rdrgx120 - not a 210!!! i know the 210 is a lg built unit - the 120 feels like its a philips built. the handset hack for the sony models posted on this forums mods the RDRGX120 to multiy region but you have to be in the system menu then press the hack and it works!!!!!!
  8. THERAAAVEN
    THERAAAVEN
    Jan 31, 2006
    587
    ruislip
    +10
    just thought as it worked helping others if they get this unit (GX120) might help!
  9. tomcatboy
    tomcatboy
    Jul 11, 2006
    2
    hi there, is there a way of changing this player to multi-region with just the standard remote or do i need one of those clever all in one remotes? new to this game so any advice very much appreciated!!!!!!
  10. Hackeroonie
    Hackeroonie
    Dec 2, 2005
    252
    Cardiff...Wales
    +18
    Tomcatboy
    To Confirm as Requested.
    All Sony Player or Recorders Cannot be Hacked with the Hanset Supplied with the Player / Recorder
    You will need the One for All Type "Special " Remote or a Similar programming device to make it Region Free
    Look under Sony on the Sticky: Hack list. Looking for a hack? Start here.
    The Various Methods Available and the Codes Needed are Well covered on the Sony Threads.
    Hope this Helps
    Hackeroonie
