Sony RDR-HXD970 + SkyHD
Discussion in 'Blu-ray & DVD Players & Recorders' started by anyarism2000, Jan 11, 2008.
  1. anyarism2000
    anyarism2000
    Feb 12, 2006
    177
    eastbourne
    +6
    howdy, this might sound a bit stupid, but if i was to redcord onto the hd on the 970 from sky hd would it record and store it as high definition?
    cheers.
  2. MuksC
    MuksC
    Aug 18, 2007
    885
    43
    +133
    no, because the Sky HD service is "closed loop", meaning you can't output to a different device in HD.
    and even if you could get HD out of the Sky HD box, the Sony 970 isn't a HD recorder anyway (you can't get HD recorders yet, apart from as drives for your computer).
    if you record from Sky HD, it will be down-coded to SD.
  3. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,132
    +7,051
    As MuksC says , you will not get HD out of it, but it is quite likely that the results will still be reasonably good as the original acquisition was of elevated quality....even though you would be recording on a SD device.
    Front end quality is extremely significant in the perception of final viewing quality almost irrespective of the viewing and degraded quality route.
    It also needs mentioning that the HD standards permit downgraded material from closed system HD devices to be at a higher resolution than SD material ... which I think will be a deliberate strategy to encourage the drive to HD.
    [ 940 is the upper resolution figure IIRC]
  4. mray
    mray
    Feb 16, 2004
    2,772
    83
    London
    +234
    Also, if you're going to keep the recording on the hard drive, you could use HQ+ mode, which is better than DVD quality.
  5. inderjitm
    inderjitm
    Jul 8, 2006
    14
    OK but what's the ideal way to connect Sky HD to the Sony HXD970 to achieve the best picture and sound quality?
    For the best picture quality , I was thinking of connecting a decent SCART RGB cable from TV SCART on the Sky HD box to LINE 1 SCART on the HXD970, a decent SCART RGB cable being something like http://www.audiovisualonline.co.uk/...75m-rgb-scart-cable-interconnect/display.html.
    This won't give me any sound though from the Sky HD box through to the HXD970 so how do I achieve that?
    BTW - the HXD970 will be connected to directly to a Philips 47PFL9632 LCD via HDMI and to an Onkyo-705 AV amp via Digital Coaxial Audio cable for surround sound.:clap:
  6. JH4
    JH4
    May 6, 2003
    2,463
    83
    +299
    A fully wired SCART from the 'TV out' of the Sky box to the L1 input of the 970 will pass RGB and audio just fine. Set the L1 input to RGB (Page 137 of the manual), and you will get a very good (if not HD) picture, when you record.
  7. inderjitm
    inderjitm
    Jul 8, 2006
    14
    Nice one JH4.
    Any recommendations for a decent, value for money fully wired SCART lead?
  8. Broadz
    Broadz
    Oct 4, 2006
    8,697
    +1,423
    The one that came with your Sky box.
