Sony RDR HXD910 crashes
Discussion in 'Blu-ray & DVD Players & Recorders' started by Baron357, Oct 24, 2005.
  1. Baron357
    Baron357
    Oct 23, 2004
    13
    My RDR HXD910 keeps crashing whenever I try to access the Freeview channels. I have tried resetting the options to factory default and the setup function still allows tuning but any attempt to access the programme guide or select TV results in a crash and the recorder restarting. Anyone else had a similar problem?
  2. Tony H
    Tony H
    I would take it back and try another model, if you still get lock ups then I would get my money back until Sony have sorted out the problems!
    Most of the earlier models have great write ups, so you could go for say the HXD 710 or just see what happens with your model. Try another first to see if it is the same.
    Tony
