Quantcast
sony rdr-hxd890
datty557
hi i bought a hxd890 3 years ago ,i read some reviews on here and it seemed pretty good.its been no hassle till now,2-3 weeks ago it started to lose the stations overnight it works ok if you tune the stations when you switch it on but loses them again as soon as you switch it off.ive done a reset on it a few times makes no difference.nothing has been disturbed or touched.any ideas before i buy another one?
ramjet
you wont buy another one as pioneer stopped making them
check the sony website for a firmware update as the 870 had one to correct the same issues
