Sony RDR-HXD870 - turn off subtitles
BarkingMad
Hi, my father in law is having trouble with his HXD870. Since the re-tune he has been seeing subtitles on the screen when viewing Freeview channels received on the recorder/player.
I've downloaded the manual and identified a subtitle button but it doesn't seem to make any difference.
There's some distance between us, so I cannot pop round to fix it.
Any ideas?
Thanks in advance
BarkingMad
Geofbob
Basic advice in these situations is disconnect the recorder at plug; wait a minute or so; then reconnect. Hopefully, this will put the system back into its normal state.
Gavtech
Administrator
Hi - Did you ever find a solution? I am having same problem!
Regards
Welcome to the forum.
Go into the menus / Initial setup / scroll down to language / across and down to 'Subtitle Display' ... and check that the setting is set to OFF.
Hisense U7H TV and T+A Solitaire T headphone reviews, AV/HiFi news plus, what is screen uniformity?
