sundancebg
The dvd recorder is connected correctly to the aerial and the TV via HDMI cable.The analog tuner works fine.My aerial signal is pretty good.I even get the BBC,ITV,Channel 4 and BBC HD channels on my LG tv.When I try to auto scan the device it doesn't find any digital channels and when I check the signal it says 0%
It plays dvd's perfectly,I've got free space on my 160gb drive and the software version is 1.65
Has anyone experienced the same problems?
The device is in mint condition and I don't want to throw it away just because of that small issue,but I want to be able to record tv programmes,which I can not at the momment...
I'd be grateful for some advice
