SONY RDR-HXD860 won't play DVD while recording
mrAverage
If I try to play a DVD while a recording to HDR is going on, it says "Operation not possible while recording".
I think this should be possible. It's certainly possible to play from the HDD while its recording.
Anyone else seen this?
k-spin
Does this happen with all DVDs? Seem to recall you couldn't play back NTSC DVDs whilst recording but PAL ones worked fine.
mrAverage
Well spotted - it is an NTSC one. Thanks.
Do you know about another problem with the machine? Sometimes a timer recording (using the EPG) continues recording after the program has ended, sometimes for several hours. Wastes a lot of HDD space.
Thanks Again.
k-spin
I don't I'm afraid. I haven't used mine for a while but I don't remember ever having that problem.
There is, however, a thread on here regarding a similar issue with the RDR-HXD560, which I think was essentially the same machine but with a smaller hard drive: Sony RDR-HXD560 record past EPG stop time
