Sony Rdr-hx900 Probs
Discussion in 'Blu-ray & DVD Players & Recorders' started by snoops, Dec 12, 2004.
  1. snoops
    snoops
    Just Bought One Of These And I Am Experiencing A Few Probs.
    1 Picture Through The Tuner Is Very Noisy Compared A-b With Tv
    2 Can You Output The Hdd/dvd Signal Via The Rf Out Or Is It Just Via Scart/component
    3 The Audio From The Dvd Is Significantly Lower Than The Hdd/tuner And The Only Way Is To Turn The Tv Volume Up Massively
    Any Body Experiecing The Same Problems?
  2. PhilJW
    PhilJW
    1. It didnt seem to bad to me, though I've only used it once as I have Sky+ which is more than enough.
    2. ASFAIK only through comp/scart. The rf is in only.
    3. I dont experience this. Playback of purchased DVDs is as loud as my old Toshiba DVD player and anything recorded to the hard drive and then copied to DVD-R is at the same volume.
    Hope this helps a bit.
