Sony RDR-HX900 HDD DVD Recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by beriks, Oct 12, 2004.
  1. beriks
    beriks
    I've just purchased a Sony RDR-HX900 HDD DVD Recorder last week.
    I've started to transfer movies from my camcorder to the recorder. I've successfully transferred some movies to DVD+RW, but when I try to burn on to DVD-R, it burns correctly, but when I place the disc in to my pc, it shows up as a blank dvd :confused:
    I do not think there is a problem with the DVD-R discs, as I have used them to transfer movies from my PC to DVD.
    Can anyone suggest what the problem may be ?
    Thanks in advance.
  2. richardr
    richardr
    May 11, 2001
    329
    28
    UK
    +49
    Have you finalised the disc?
  3. beriks
    beriks
    :oops:
    thanks. yeah, that was the problem.
    cheers for that. :thumbsup:
  4. deacon43
    deacon43
