D
dw1963
i have had a sony rdr hx900 dvd/hdd recorder for almost 3 years now and for some time have had problems dubbing from hdd to certain types/brands of media, as summarised below;
verbatim dvd-r - initially worked fine but when i started using a new batch of discs, dubbing would start, after a few minutes the process would stop, the 'disc is dirty' message would appear and the machine would go into 'safety mode',
phillips dvd+r - machine would not accept these discs, displaying 'format failed', 'disc is dirty' messages
kodak dvd+r - bought last saturday. dubbing from hdd worked fine with the first disc. i tried 2 more and in each case, several minutes into dubbing the process would cease and the error c13 'disc is dirty' message would appear
the following types of disc work with no problems;
tdk dvd +r/w, tdk dvd+r, kodak dvd +r/w.
almost 2 years ago i bought a denon dvd1920 player which became my primary playback source and thereafter the dvd drive in my sony was never used, except for occasional dubbing from hdd to disc. I have wondered if the laser lens might have become dirty due to lack of use and have considered trying a dvd lens cleaner. unsuprisinly the user manual warns against using such devices, as 'a malfunction may result'
has anyone out there got any idea what might be causing these disc compatibility problems, or had any experience of using a dvd lens cleaner in the sony rdr hx900?
thanks
thanks
