Sony RDR-HX 1000 Multiregion where to buy
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kamin99, Sep 15, 2004.
  1. Kamin99
    Kamin99
    Sep 15, 2004
    356
    +12
    After reading a german reviw and the specs of Sony RDR_HX 1000 with Pal/Ntcs progressive scan ,i cant wait to get my hands on this DVD-HDD with 250GB Recorder,i ve seen it on http://www.avland.co.uk/ with multiregion as well but they dont ship to Ireland so would you guys know of another trusted site
    appreciate the help
  2. ernet
    ernet
    C'mon be so kind and sent the link where you read it.
    I,m ready to buy RDR HX 900 at any time however I don't thin it is avaieble already. IMO i think it's the best choice of today.
  3. Kamin99
    Kamin99
    Sep 15, 2004
    356
    +12
    sorry tried to remember the german site but no luck ,but hereare the specs
    250gb Hard Drive, for up to 325 hours recording!
    HQ+ (High quality +) 15Mbps HDD mode for ultimate quality recording
    Up to 24x Speed Dubbing from HDD to DVD (4x in SLP mode)
    Bi- Directional Dubbing DVD<->HDD
    Simultaneous Record/Playback (VR Mode)
    DVD+RW/-RW/-R DVD Format Recording Compatibility
    12-Bit Video DAC with 108Mhz Processing w/NSV
    192kHz, 24-Bit Digital-to-Analog Converter
    Video mode for recording discs that will play in most existing DVD player
    Record in real-time using MPEGII compression-Up - to 6 hours per DVD-RW disc
    Analogue Nicam TV tuner built in with RF pass through
    Videoplus+, PDC, & Manual Timer Programming
    Sonys Smartlink feature
    2 Scarts Full RGB in and out
    Minidisc style Non-linear editing
    Coaxial digital out
    Component video out
    PAl/NTSC Progressive scan
    Modified with our Sprinter Software multiregion upgrade:
    Auto region playback
    RCE Compatible (Plays RCE Discs)
    No Chip, soldering, or case removal - GUARANTEED!
    430 x 89 x 381mm (WxHxD)
    Weight 5.1KG
    1 Year RTB Guarantee
    http://www.homecinemaheaven.com/prod_info/dvdrec/rdrhx100.htm
  4. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    What about the Pan DMR 500? It has a 400GB HDD, is out in Oct I think!? and the Jap version has a feature whereby you can text it to begin recording if you've forgotten to set it, (and there's no one at home). Still, I guess you'd need to have it on the right channel. Hmm...would be good if you could text the details and it would record the channel you want, set the hours etc....
  5. tuono
    tuono
    Sep 3, 2004
    47
    Wow this does look good......even better I've just found it for
    £678.95 inc p&p!!!!!!!!!!!!!! :clap:
    However.....
    If you live within one of the following postcode districts or outside of the UK please email or telephone for a delivery quotation - BT, PA, ML, EH, KA, G, KY, PH, DD, AB, IV, KW, HS, ZE.
    Please note we do not send goods outside of the UK or to BFPO addresses (Eire included).
    Does this preclude you Kamin??
  6. ernet
    ernet
    Thanks Kamin99 for your reply. But in the meantime pls. skip to my new thread called " Sony RDR-HX900 HDD.Did Sony make a stupid mistake ?! " and comment it. I can't even imagine that it is true !
  7. TonyK
    TonyK
    Oct 30, 2003
    Hove
