Sony RDR-GX300 & SKY+
Discussion in 'Sky Digital TV Forum' started by gary2005, Apr 4, 2005.
  1. gary2005
    gary2005
    Ive searched the forum for help but i dont seem to be able to find any info that helps. I have a Sony RDR-GX300 DVD recorder and sky+. I have the it set this way:
    SKY+ TV Scart into LINE3-Decoder of Sony DVD
    Sony DVD LINE1-TV scart into the TV.
    This allows me to switch between watching Sky and watching a dvd by pressing TV/DVD button on the Sony remote. However, i can't record either from a live broadcast or a stored recording on the Sky+ HD.
    Any help would be welcome.
    Gary
  2. BigRD
    BigRD
    Jul 4, 2003
    393
    far far away
    +14
    This sounds familiar to me! My Brother-in-law had the same problem and I'm sure it was fixed by pressing a select input button on the remote. This was different to selecting line1 - 2 - 3 etc.
    HTH
  3. mrtbag
    mrtbag
    Dec 17, 2002
    3,652
    Anywhere I want
    +394
    On the DVd remote, there will be an input select button. Press this until L3 is on the display of the RDR unit. Whatever you are wathing on sky will be output to this.
  4. gary2005
    gary2005
    Thanks for the tips. The input idea was sort of the prob'. I had to go into advance and alter the input settings first and then choose the right one on the remote.
    Thanks again
    Ga :thumbsup: ry
  5. gary2005
    gary2005
    Thanks again
    Gary
