Sony RDR-GX300 Multi-Region Hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by ChoccyTV, Feb 18, 2005.
  1. ChoccyTV
    ChoccyTV
    Anyone know where I can get a multi-region hack for the Sony RDR-GX300? :lease: Preferably without paying for it? :D
  2. banjo21
    banjo21
    Oct 3, 2004
    1,620
    63
    Wirral
    +149
    prepare: your one for all
    1. select dvd device on remote
    2. hold magic button until flashes twice/comes out
    3. enter device code 0533 (this programe the GX300 as the DVD choice in your one for all)
    Now program buttons 1..5 with the following codes using the instructions below:
    1 - 189
    2 - 255
    3 - 095
    4 - 221
    5 - 079
    1. hold magic button until rabbit comes out
    2. press 994
    3. press magic
    4. enter 3 digit code from above
    5. press button (1..5) where to program it
    6. repeat steps 1 to 5 for all keys.
    have it a go:
    1. remove disk, put player on standby
    2. press 1,2,3,4,5 - success is displayed and plyer starts up
    3. press 1,2,3,4,5 - player shuts down and BINGO!
  3. DaveF327
    DaveF327
    Dec 26, 2007
    3
    I don't have a "one for all"
    How do I do it with the standard remote?
  4. stuart1976
    stuart1976
    Apr 18, 2007
    1,080
    Timsbury, Bath
    +252
    You can't do it with the remote that came with the unit. You will need to get a OFA Remote.
    I got the GX350 last week and had to get a OFA to make it multi region. Worked first time.:smashin:
    Got the remote from Argos for £14.99
  5. cheradams
    cheradams
    Jun 15, 2010
    3
    Hello
    I followed your advice and got a OFA Kameleon URC8210 remote.
    i managed to log my Sony rdr gx300.
    But, i don't get to do the next steps.
    once i press the Magic Button, the rabbit does come out but i don't have anymore access to the numbers,
    the remote hides the numbers and i can only press the upper menu buttons...
    this is driving me crazy. am i missing something in the procedure?
  6. cheradams
    cheradams
    Jun 15, 2010
    3
    Hello
    thanks in advance for your help
    Karen
  7. cheradams
    cheradams
    Jun 15, 2010
    3
    Hello
    Thanks in advance for your help
    Regards
    Karen
