Sony RDR-GX3
Discussion in 'Blu-ray & DVD Players & Recorders' started by thursty, Feb 23, 2005.
  1. thursty
    thursty
    recently purchased RDR-GX3 as I needed an all region DVD player only to discover that it doesn't actually play DVD's from all regions !!
    I have purchased a couple of DVD's from the USA that are DVD-Video format Region 1 and these are not playable !
    So other than going back to Sony and have an argument about product descriptions can anybody advise how to get round this ?
    I understand that you can recode DVD players to take off any region restrictions ? If this is an option whats the best method ?
    Failing that can anyone recommend a cheap player that will play Region 1 DVD-Video ?
    Many thanks
  2. Dean
    Dean
    Jun 20, 2003
    2,690
    London
    +188
    Most shops offer a firmware update that will allow multi-region playback. The sony you mention is a DVD recorder, quite a good one at that as I have one in another system and the playback quality is good. Otherwise there are loadsa budget players to choose from which are multi-region.
  3. banjo21
    banjo21
    Oct 3, 2004
    1,552
    63
    Wirral
    +127
    search on my posts - me and others have listed a remote hack for this at least twice
  4. thursty
    thursty
    I have found the post that describes the hack using an all for 1 remote.
    Unfortunatley I dont have one ...the remote I use is that Sony remote that came with the player. Is there a hack instruction for that device ?
    Alternatively if someone can recommend a site where I can purchase a fimrware upgrade that would be good, I dont mind paying a few quid to get over the problem.
