Sony rdr-gx3
Discussion in 'Blu-ray & DVD Players & Recorders' started by bluesfan, Aug 19, 2004.
  1. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    If anyone is looking for a simple dvd recorder without HD I can recommend. Quality is second to none, menus easy to use. Only a few left as Sony new models soon.
    Having sent back Philips dvd80 and Pioneer 420 I should know as I'm fussy.
    Got mine in black from Germany £250.
  2. jonjonjon
    jonjonjon
    Jul 13, 2004
    75
    +3
    Other posts on this model have suggested that although the picture quality is impressive, the fan can be quite noisey.
    What's your opinion? With the TV off and standing about 2 metres away what's the noise like?
  3. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    All fans are noisy whatever people say. Slightly bigger fan more hum than whine.
    I thought the fan was less noisy than the Pioneer 420 but then that it combined with the HD.
    I am considering fitting a fanmate but up to now isn't too bad and I sit 3ft away.
  4. AlanDL
    AlanDL
    I have just got GX3, to replace my Philips 880 (I know!); had changed it for a Philips D70 (my transitional machine before a new HDD/DVDR Digital, probably next gen Toshiba), but took this back quickly when Sony's came down in price. Can use all my many +RW discs, but can now buy new -RW discs ready for new machine. Sony can act as a secondary recorder then.
    Fan noise minimal; I sit close to it, and no difference from Philips (if not less!).
    Only thing I miss is 2h:30min rec mode which I had on Philips, and can't edit anything on +RW; and -RW VR mode is not compatible with portable player or any other players I have, so basically lost editing capability if using on other machines. But I can live with that. Sony feels a much better quality machine. Heartily recommend it; although I have had it only a couple of days!
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,856
    Warwick
    +2,777
    If you have a PC then why not follow the VR to DVD-R conversion guide found here. If you don't already have one PC DVD burners can be picked up from £50.
    Depending on how long you spend on menus etc the conversion can take just minutes of your time (and maybe an hour of processing/burning on your PC). On the other hand if you become a menu/chapter point perfectionist then it can take hours ;)
  6. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    I use a Plexor 708a on my pc. It supports both +rw and -rw.
    The editing issue is no big deal; to be honest I haven't the time to take out adverts.
    Design wise it's the best looking dvd recorder about (esp in blk). Ugly Panasonic take a lesson.
  7. AlanDL
    AlanDL
    Thank you Rasczak; the only error you make is responding to me as if I was anything other than cheap! All the recordings I would use on a portable are going to be temporary recordings, so wouldn't waste -R on that! Thanks for tip though. I have simple requirements really; best thing is the quality of the recordings from Sky rather than any other editing requirements.
    Also thanks for all your comments to everyone; extremely illuminating, (I don't know where you get the time, you need to watch more TV like me),
    especially on next generation HDD/digital recorders; I think I might skip the Sony (appears they have just one an award) and wait for the Toshiba next year.
  8. Rasczak
    Rasczak
    Apr 3, 2002
    21,856
    Warwick
    +2,777
    It works with DVD-RW, DVD+RW and DVD+R too ;) but I get your point.
  9. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    Can you make the gx3 multi region,just bought one.
    As for fan noise,hardly noticable tbh.
  10. denson
    denson
    The fan noise on the Sony is not noticeable...build quality and picture quality as well as ease of use are all A+. I will highly recommend it, especially as the price is plummeting due to the release of the new model. I am in the process of making mine multi region. Will keep you posted. It is supposed to be a simple remote control hack.
  11. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    am looking too,cheers.
  12. Hyp3rion
    Hyp3rion
    Oct 11, 2004
    38
    9
    I also have the rdr gx3, nice machine. The fan is audiable but you only notice it when you turn the tv off for bed ;)
    I got mine chipped almost straight away from DvD codes , they sent a hacked remote along with a prepaid recorded delivery slip so you can send the remote back afterwards :clap:
  13. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    So how does that work then?
  14. Hyp3rion
    Hyp3rion
    Oct 11, 2004
    38
    9
    They send you a preprogrammed remote, you point and push the red button, machine goes beep, send remote back :cool:
  15. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    A bit concerned about how safe it is though,i'd rather sony did it for me.
