Sony RDR-GX3 Owners
simon1
Established Member
Have any of you seen a vertical white stripe appear briefly on screen, when changing channels on the recorder or when powering on/off?
Mine's doing this occasionaly.
I Need to establish quickly if this is a fault or not.
PhilipL
If this is only happening on changing channels or turning the machine on or off, what problem do you have with that?
It sounds like nothing more than a brief change in the output causing an odd anomaly on the TV and nothing to worry about. Having some interruption to the picture when changing channels or switching the thing off sounds pretty normal to me.
Regards
Philip
simon1
Established Member
Thanks for the replies chaps.
The line is very obtrussive, and not what you would expect on Sony equipment, especially at this price.
Also, I've just noticed the unit is vibrating at certain times, which gives off quite a bit of noise - will be getting it replaced.
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
