Sony Players and VBR
Discussion in 'Headphones, Earphones & Portable Music' started by Chox1988, Sep 7, 2005.
  1. Chox1988
    Chox1988
    Mar 30, 2005
    16,821
    basingstoke
    +9,278
    I have a NW HD1 and have loads of mp3's in Variable Bit Rate. Was wondering will it convert VBR into Atrac or will it just not work, will they have to be a constant bit rate?
    Cheers :thumbsup:
  2. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Well I have an HD3 and it transfers VBRs straight across, so I would imagine it will convert them fine.
  3. HD3
    HD3
    What harm would it do to try it?
  4. Chox1988
    Chox1988
    Mar 30, 2005
    16,821
    basingstoke
    +9,278
    There on another PC and transferring them across the wireless isn't fun.
  5. HD3
    HD3
    Try it with one file first, then do the rest if it works
  6. Chox1988
    Chox1988
    Mar 30, 2005
    16,821
    basingstoke
    +9,278
    Didn't think of that :suicide: . It worked :thumbsup: .
    Cheers everyone. :smashin:
