Sony Plasma needs a new DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by grahammackie, Nov 28, 2003.
  1. grahammackie
    grahammackie
    I have a top of the range Sony Plasma (PFM-510) which cost me a small fortune a few years back. I also have an original Yamaha S700? DVD player that has given up the ghost.
    Good excuse to treat myself to a nice new DVD.
    Am looking at Denon 2200 or 2900 but cannot tell if my Sony Plasma supports progressive scan. It is blessed with multiple inputs but I only use S-video at the moment. It has component input but it is a bnc connected setup. The spec in the manual says it has:
    RGB 0.714 Vp-p/non-composite, 1 Vp-p/composite, 75 ½ automatic termination, loop-through
    YUV 0.7 Vp-p/non-composite (U/V), 1 Vp-p/composite (Y), 75 ½ automatic termination, loop-through
    HD/COMP, VD H (or composite) sync, V sync, 1 - 5 Vp-p, high impedance, loop-through
    Which means nothing much to me at all I am afraid. My amp supports 3 pin phono component out - is it worth spending the money on a PS DVD player ?
  2. grahammackie
    grahammackie
    Oops - I think the BNC's are in fact RGB inputs. Does this rule out the use of progressive scan ?
  3. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    The BNC component inputs can probably accept YPbPr (YUV) or RGB. I'd get a progressive scan dvd player, and a set of good quality RCA to BNC cables. I'd imagine that it would work with progressive scan dvd player but it may need some tweaking to get a good image as it will probably be optimised for PC use.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    look at the HK DVD 25/30 PAL and NTSC Prog Scan
  5. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Got my HK DVD25 yesterday and it's fantastic. A noticable improvement over my tosh 220.
  6. grahammackie
    grahammackie
    Hornydragon,
    Will I be able to use the Pal PS feature of the HK even though I will end up doing a component to RGB conversion ?
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    ??? does the SONY not take YUV??? most plasmas will on their RGBHV input if set up for it in menu Fujitsu do this, Might be worth checking with sony, dont do Sony so cant comment on that screen sorry mate!
  8. grahammackie
    grahammackie
    Hornydragon,
    The tch spec says that the current 5 BNC connectors support the following, is this true YUV ?
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Should be able to use the 5 BNC to get YUV then mate and if the screen will do prog scan use that.
    System on 5 BNC seems very similar to the Fujitsu HHA/VHA
  10. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    The Arcam players can output progressive RGB or YUV...
  11. grahammackie
    grahammackie
    Sorted. Borrowed a friends Camb Audio prog scan DVD500 and a cable from Keene and I got a prog scan picture when I selected a combination of RGB1 & YUV on the input remote.
    Picture looked a bit sharper but not sure the player was the best there is !!
    Have ordered a Denon 2200 as I could with the SACD & DVD-A functionality.
