Sony Plasma jumping!!
Discussion in 'Sony TVs Forum' started by Mr Forgetful, Sep 6, 2004.
  1. Mr Forgetful
    Mr Forgetful
    Jun 7, 2004
    377
    West Midlands
    +15
    The picture on my Sony KE32 Plasma seems to be jumping to one side every 6 or so seconds, it is only a tiny jump but now I have noticed it, it is very very annoying, is there a comman problem with this or is it knackered, is it possible that a Sub's magnet has caused this. Is it something that can be fixed or will I need to chuck it away and save for a new one?
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Could it be that you have the screen saver function switch on...that moves the image around the screen ever so slightly to help reduce screen burn...might be worth checking.
    Cheers, Lee
  3. Mr Forgetful
    Mr Forgetful
    Jun 7, 2004
    377
    West Midlands
    +15
    I will check as soon as I get home, so you think it might cause this even while watching through normal TV viewing, watching a DVD and through a Digital Freeview box?
  4. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    Yeah it could well be the cause...it's a feature of some plasma screens and when selected will move the screen a couple of pixels to the right, then down, then right and then up as I understand it.
    It drives some people mad and other's don't see it or mind it at all.
    You should be able to either turn it off or adjust it's speed etc but I'm not that familiar with your screen.
    Cheers, Lee
  5. Mr Forgetful
    Mr Forgetful
    Jun 7, 2004
    377
    West Midlands
    +15
    Cheers Lee, i'm now hoping it is only that, and not something more serious, it is really driving me up the wall, if I remember right, I did put a screen saver on it, a plain blue screen!!
  6. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    Perhaps screen saver is the wrong term...sometimes they call it a screen 'orbiter' or something similar.
    It can't hurt to check anyway.
    Cheers, Lee
  7. Dr Downey
    Dr Downey
    Jan 12, 2004
    124
    19
    Cheltenham
    It is the 'screen saver' function. The image does an orbit on the screen every so often. It decreases the possible 'screen burn'.
    You can turn it off in the on screen menus.
    I've left mine on, took a while to get used to it, but hardly notice it any more.
    If you do decide to chuck it away, then I'll bring my skip round!! :D
    Cheers!
  8. Mr Forgetful
    Mr Forgetful
    Jun 7, 2004
    377
    West Midlands
    +15
    Thanks for your help, I could not get used to it, i found it very annoying but last night I switched the screensaver off and it was fine after, once again, thanks for your help, much appreciated!!
    Dave. :thumbsup:
  9. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    Excellent stuff...I don't think I could live with it either.
    Cheers, Lee
