Sony PFM-42VIE & SKY+ HELP
Discussion in 'Plasma TVs' started by Richie938, May 11, 2005.
  1. Richie938
    Richie938
    I'm having problems running Sky+ through my Sony PFM42VE1 -
    My set up consists of
    1. Sony PFM42VE1 with BKM - V11 Component/RGB Interface
    2. Sky +
    3. Onkyo D989 A/V Amp
    4. Sony NS930V
    I have run the DVD palyer through the Component Input in the back of the Reciever then from the component out on the receiver to the BKM - V11 and it works perfectly -
    I have tried running the Sky in a similar was (Scart to Component but I am only connecting to the Plasma using the 3 Components, i'm not using the H/V Sync) but no picture, it will flicker now again and that's it.
    Can someone Help !! as I've tried looking for a External Tuner with the right Inputs and outputs but can't find anything or is it a case that my set up is wrong.
    Richie
