Sony PFM-42B1E/S £3406inc. 42" Plasma 1024x1024
Discussion in 'Sony TVs Forum' started by Rob.Screene, Jan 18, 2003.
  1. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,314
    Berks, England
    +140
    I just noticed this in Scan.co.uk's today only page.
    I can't vouch for what Scan are like at supplying such a thing. I am also only a vague follower of Plasma technology.
    The 1024x1024 resolution sound interesting, it apprears many plasmas sold are still only 640x480!
    I assume there's no tuner module, but it looks to have Component input(s?) "HDTV (Y/PB/PR, RGB) "?
    I wonder how it compares to the Panasonic and Pioneer leaders for domestic use (solarisation, contrast range, buzzing, flicker and clarity)?
    regards,
    Rob.
    Sony PFM-42B1E/S 42" Plasma Screen!
    107cm/42 inch, 16:9 widescreen, 1024 x 1024 pixels XGA resolution plasma screen
    The PFM-42B1E/S uses a high resolution flat panel with true XGA and 1024 x 1024 pixels. Achieving excellent brightness and contrast, it produces sharp, detailed images with rich and natural colors.
    Size control.
    The size of the picture can be adjusted both vertically and horizontally.
    Picture zoom.
    The digital picture zoom function can be used to show a close up of an individual image. In addition it allows the PFM-42B1E/S to be used in multi-screen video walls with 4, 9 or even 16 screens and this without an additional picture processor.
    Various remote control capababilities.
    The PFM-42B1E/S is controllable with the supplied RM-42B remote control unit or via RS-232C interface. Via the On Screen Menu (OSD) the control buttons on the Monitor (including the Power Button) can be disabled so that nobody can alter your settings or switch of the monitor
    Panel Resolution: 1024 x 1024 pixels
    Pixel pitch: 0.90 x 0.51 mm
    Active area: (W/H) 921 x 522 mm
    Viewable picture area: 42-inch/1,058 mm (measured diagonally)
    Driver 10-bit RGB
    Colours: 16.8 million colors simultaneously
    Type: AC-type Plasma Display Panel with anti-reflection screen
    Color system: NTSC / PAL / SECAM / NTSC 4.43 / PAL 60
    HDTV (Y/PB/PR, RGB)
    Sampling rate: 13.5 to 140 MHz
    Preset signals: more then 38 pre defined signals
  2. jonathan
    jonathan
    Feb 8, 2002
    160
    19
    Kent
    I notice that they have the 32" display listed at the same price (!) so I think it must be a mistake. Also it is listed as a "kit". Hmmmmn........interesting. Does this mean you've got a self build when it arrives?:D
  3. Adlopa
    Adlopa
    Nov 25, 2002
    74
    That price doesn't seem to be too wide of the mark -- other sites list it at around £3,600. And isn't XGA (how the monitor is described) 1024 x 768..?
  4. pwhite8314
    pwhite8314
    Jan 4, 2003
    117
    16
    Fort Worth
    Just a quick word of warning, IMHO, Scan are the worst etailer I've ever dealt with, and I certainly would not trust them with a purchase of this size. I'm not alone in this view!
  5. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,314
    Berks, England
    +140
    I too have had many good and a few bad purchases with Scan, nothing too horrific.
    I wouldn't even contemplate a mail-order purchase like this unless from someone recommended to me by at least two people!
    I found another few specs under http://www.business-presentations.co.uk/plasma1.htm
    Screen size: 42"
    Contrast: 500:1
    Aspect ratio: 16:9
    PC Inputs: 2
    Video Inputs: 1
    Video compatibility: PAL, SECAM, NTSC
    Weight: 29.4kgs
    With mentions of improved I/P processing, which I think means better deinterlacing, probably doesn't mean anything about internal scaling quality!
    cheers,
    Rob.
