Question Sony performance and the Android issue
Discussion in 'Sony TVs Forum' started by AlanX, Mar 9, 2018.
  1. AlanX
    AlanX
    Feb 5, 2010
    464
    46
    West Sussex, UK
    +142
    Many here have bemoaned the performance of the Android OS in Sony TVs. So here's my question ...
    If I'm using my TV as little more than a monitor - that is, audio processed externally through an AV Receiver, and with only occasional non-critical web activity direct to the TV - will I feel any impact of the poor performance of the OS?
    And if I'm using the TV to process one or other HDR standards, will that be impacted by Android's limitations?
    I can't work out whether it's a real concern for my particular circumstances. Thanks for any feedback.
  2. Bastille
    Bastille
    Aug 20, 2017
    207
    London
    +254
    It really isn’t an issue if you don’t use it.
    I’m going to buy a Sony TV soon, I couldn’t care less about Android as I will control the TV via my receiver and Sky Q + Apple TV 4k, both of which are way better than any smart TV system out there.
  3. Norman
    Norman
    Jul 14, 2000
    1,734
    116
    Herne Bay
    +592
    I found the biggest performance issue was caused by using the built-in tuner and YouView.
    Now that I use an external tuner (Freesat box) I find my XE93 Android Smart platform works ok.
  4. Russ_64
    Russ_64
    Jan 20, 2005
    449
    2
    46
    London
    +161
    Agree with all comments as I also use Sky Q and not built-in tuner. I also do not find the menus to be that slow compared to my other Sony TV.
  5. GadgetObsessed
    GadgetObsessed
    Jul 6, 2001
    2,446
    116
    +1,144
    I use my Sony ZD9 as a monitor (Amazon and Netflix via other devices - broadcast TV via Sky Q) and Android doesn't cause any significant issues at all for me.
