Sony Perfection !!!!!!!!!
Discussion in 'TVs' started by the plumber, Feb 20, 2003.
  1. the plumber
    the plumber
    After 4 Toshiba 36Zt29b's and dark patches galore i finally returned my sets and exchanged them for a 36NX200 and i dont believe it "PERFECTION" not a blemish to be seen ,perfect geometry and convergence and a picture to die for .
    After finding my way into the service menu and making a few very minor adjustments i truly believe i have the best 36" tv i have ever seen ,the digital tuner is superb and dvds look awesome
    DRC50 works excellent with NTSC discs.
    And before you ask "NO" i dont work for SONY in fact i was a dedicated tosh fan until now :eek:)
  2. KANU25
    KANU25
    Good to hear that - Where did you buy the TV from?? How much was it??
    Is it good for sky digital?? footy?? cricket??
  3. Bam
    Bam
    Glad to hear it plumber.
    As you have a perfect picture would you mind posting the service menu deflection settings on manumans post:smashin:
    I also want a reference guide for when mine eventually arrives, all be it the FS76.
    Bam
  4. the plumber
    the plumber
    Bought it from sound & vision in bolton £1790 and could not recommend them highly enough , everyone i dealt with there was very courteous and helpful and actually knew about about the products they were selling (which makes a refreshing change) . as for the settings .....i noticed when i set the tv up there were horizontal scanning lines visible when using DRC100 andd also the tops of the screen logos were missing so i reduced the vertical picture size by a few millimetres and presto perfection !!!!!!!
  5. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
  6. Lpool
    Lpool
    Can you explain what you did? I have FS76 and only use DRC50 because the horizontal lines are so visable and enoying on DRC100
  7. ScottyToo
    ScottyToo
    Oct 13, 2002
    94
    Essex, UK
    +3
    I have exactly the same and thought I had a fault on DRC100.
    I'm really interested to find out about the adjustment to make it work. How did you shrink the picture by a few mm?
  8. the plumber
    the plumber
    Go into the service menu (hold down prog up and prog down buttons on set while switching on ) then press menu twice and you get the service menu.
    Go into deflection and alter vertical size its as easy as that !! :eek:)
  9. gbmitie
    gbmitie
    Apr 25, 2001
    1,120
    48
    republic of ireland now
    +56
    Do u have sky and do u watch the footie? If u do how does it look on your new set? Everywhere I read footie is absolutely terrible on new tv sets.
    gb--
  10. the plumber
    the plumber
    Yes i watch the footie ,,,,watched the Newcastle game on tuesday and the picture was fine ...watched it in DRC50 and DRC100 and both looked great to me .
  11. ScottyToo
    ScottyToo
    Oct 13, 2002
    94
    Essex, UK
    +3
    Thanks.
    Used and it did the trick.
    Inceidently I found that if you turn the set on like this, you can go striaght to the service menu by pressing the left arrow on the remote.
    Scotty
  12. KANU25
    KANU25
    Thanks Plumber!!
    I ordered my 36nx200 this morning from Sony Centre(its reduced from £2300 to £2000 - but I'll be using barclaycard pricematch anyway) - they seemed to be the only place that had it in stock. They check direct with Sony and had 25 in stock!!
    Already got phone call that they will deliver it on Wednesday morning...can't wait!!!
  13. SHINODA
    SHINODA
    Plumber, stop bragging, lol.
    Im still waiting to get my Panny TX-32PL10 sorted out, hopefully that will be very soon.
