Sony PEG - TJ35.... PDA Question.
Discussion in 'Mobile Phones Forum' started by Greeno4England, Dec 27, 2003.
Tags:
  1. Greeno4England
    Greeno4England
    Hi All.
    Got a new PDA for Xmas and having problems putting music and pictures on it from my PC.
    Got all the correct leads but when i try it says something about no memory stick?
    Do i have to buy an memory stick for it before i can put things from my PC onto it?
    If so does anyone know how much these memory sticks cost, and roughly how many mp3 tracks would i be able to put on one?
    Cheers everyone.
  2. Gurteltier
    Gurteltier
    Absolutely right - the Clie's mp3 player only play back mp3s stored on a memory stick (not on internal memory). A 128Mb Memory Stick retails for about 35 quid and at normal 128kbps quality can accomodate about 2 hours worth of music. Once you have a memory stick in your Clie and hook it up to your PC starting the program MS Import (on the PDA) makes your memory stick appear as a removable drive on the PC. You can then simply drag and drop music to your hearts content.
    I don't know for sure but if you are lucky your new Clie can support the larger capacity Memory Stick Pro cards - these go up to 1Gb in size and allow a heck of a lot more music. The costs does of course however go up too.
    Lastly, for purely mp3 playback be advised you do not need to buy Sony Magic Gate memory sticks - in fact you don't need to buy Sony memory sticks at all. Cheaper alternatives are available from Sandisk and Lexmark amongst others.
    Hope that helps,
    Neil
  3. Greeno4England
    Greeno4England
    Cheers for your reply :)
    I got a memory stick and can now put pictures and music on to my PDA, I couldnt beleive how crystal clear the music was, bearing in mind that wasnt going to be my main use for my PDA and tbh i didnt even know you could put music on them, its a great side benifit to add to what i was going to use my PDA for!
    Got a 128MB card and even managed to compress a music video down and put it on! hehe, very cool :)
    Once again, thanks for your reply :)
