Sony PC120E copying video to PC/DVD
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by AV novice, Aug 6, 2003.
  1. AV novice
    AV novice
    I am connecting my Sony PC120E to my high spec PC via USB cable in order to download video and burn to DVD. I installed MGI VideoWave 111 SE which came with the camcorder and also the USB driver.
    I am able to download still images which I have stored on my camcorder memory stick. Therefore, I know that the USB connection is working. However, I am not able to view any video through my PC when I play it on the camcorder.
    Any help would be really appreciated!!!:confused: :confused: :confused:
  2. ChunkyBits
    ChunkyBits
    Dec 12, 2002
    5
    Boro
    I have a Sony TRV60 and I had to enable USB video streaming in the setup Menu. ... where things like sound-quality, AV In etc. are lurking. Maybe there is a similar enable for the PC120E buried within the menus somewhere?
  3. David
    David
    Nov 26, 2002
    221
    16
    London
    The USB connection is mainly for downloading stills. For video you need to use the firewire (i-link) connector, which means you will need a firewire card in your computer. USB is not fast enough.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    As stated, USB is not designed for capturing video. It can be used for quality stills capture or webcam quality video. Even USB 2.0 is not fast enough.
    If you do want to edit video on your PC then get a PCI firewire card from somewhere like ebuyer.co.uk for around £20. Just install in a spare PCI slot and Windows will do the rest next time its booted (as long as you are running Win 98SE or later).
    Mark.
  5. AV novice
    AV novice
    Thanks for the tips guys. Today I bought a SIIG Inc Firewire complete DV editing pack which includes 3 port adaptor, DV cable and Ulead Videostudio 6. Now I just need to plug the adaptor into the PC which should be fun as I have never had to delve into the guts of a PC before!!!
    The above package cost 50 quid from PC World but I had to have it today and no doubt ended up paying through the nose!!!
    Thanks again :D
