Quantcast
Sony pc100e still picture grab query
rooster
Ihave set still picture to 1152 x 768 on the above camera but when i connect to PC via firewire and grab pictures they come in as 320 x 280 . Anybody know what i am doing wrong?
MarkE19
I think I am right in saying that when you save still images to DV tape and then transfer via firewire you are only able to transfer at DV resolution (320 x 280) as it is saved to the tape in DV format.
To transfer at 1152 x 768 you will need to save your images to 'memory stick' instead of DV tape.
Mark.
rooster
The pictures are on memory stick but i guess by using the firewire card . I am transfering the picture from the LCD screen rather than stick. So i probably need to use memory stick reader then .
Thanks for the reply
