SONY.......PANNY........or Pioneer
Discussion in 'Blu-ray & DVD Players & Recorders' started by mercman1969, Dec 3, 2004.
  1. mercman1969
    mercman1969
    Nov 12, 2004
    64
    what is best buy for sub £200
    Want to be able to play my recordings on any machine in the house (DVD -R/RW) is this right?
    Any help
    :lease: :lease:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    In which case you should avoid the Panasonic range as their re-writeable media (DDV-RAM) will not play in most DVD players. The Sony and Pioneer both use DVD-RW which will play in most - but not all - DVD players. All three brands also record to the universally compatible DVD-R.
    Which one for you depends on numerous factors dependant on what is more important: recording quality or DVD playback, what sources do you want to record from etc etc!
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Panasonic=incompatible
    Sony=overpriced
    Pioneer=The mutts nuts
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    what will you record from? Sky, cable analogue etc?
  5. mercman1969
    mercman1969
    Nov 12, 2004
    64
    unsure as this is the top prize in our xmas draw
    only concerned about giving them as many options as possible!!
    cheers
    Pete :lease:
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    JVC????
    SONY will get the most Joe bloggs eye apeal.....
  7. mercman1969
    mercman1969
    Nov 12, 2004
    64
    which model
    where to buy it from please for best price
    like i said dont think it will go to an AV guru, so features arnt an issue....just got to be functional with the best range of uses
    cheers
    Pete
  8. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    Pity the person who follows your advice Phelings and uses DVD-RW VR mode - he ends up with a disk just as incompatible as a DVD-RAM only recorded with worse PQ than the Panasonic.
  9. SDHoward
    SDHoward
    Nov 1, 2004
    250
    And what about the Toshiba?....
  10. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It would be the Panasonic E55 for me every time. I don't care that DVD-RAM is incompatible (which it isn't, see below), it's much more versatile. If you're really worried about compatability, get one of these to fit in your PC for £13 :) It's more the case that your PC isn't up with the latest technology, not the Pannie :laugh:
